JHZR2
Staff member
Hello,
Just curious if anyone can give the 30-sec. rundown of thread selaer vs. locker.
My issue is this - I have a series of bolts that are specced for 89 in-lb of torque for full tightness. They are in an application that gets very hot and then cools to ambient.
My issue is that I need a substance that keeps the bolts in place properly at these high temperatures, but is not so strong that it will be impossible to get these weak, small bolts back out in the future, if needs be.
Threadlocker red just has such a strength above and beyond what the bolts can take, that i worry it might grab too tenaciously.
I found a high-temp thread "sealant" at the auto parts store, which, though not making any real clamims about holding the parts in place like a threadlocker, at least claims it prevents leaks at high temperature, vibration, etc.
So all I want to do is hold weak bolts that are not torqued very highly in place in a high-temp, high-vibration application (they are the bolts that hold the upper oil pan to the block, FYI).
Is hi-temp thread sealant the right stuff for this application, or am I better off using the lower temperature-rated, blue or red threadlocker?
Thanks
Thanks
