Oil analysis is often used to detect condition of engine as well as life of engine oil. I was just wondering if smog test results can also give a good indication of the condition of an engine. I am sure the equipment used is also pretty sophisticated.
Yes, I know a compression test is the way to go but some buyers might not want you poking into their cars and also for some engines, a compression test alone can run $300 or more? What about the smog test results? Here in CA, a smog test is required when a car is sold.
I just did a smog test on my Lexus 1992 LS 400 with 200K miles. Results seem to say that engine is in good shape.
And here are the results:
HC (PPM) CO(%) NO(PPM)
15mph 2 (102 max allowed) 0.02(0.68 allowed) 45 (748)
25mph 0 (77) 0.01(0.55) 68 (687)
