My 1998 Z28 has 169K on it and does tend to get the well known piston slap noise on some cold startups. In the past couple years, I've tried about 8 different types of conventional and synthetic oils to see which ones help the noise the most (all have been 5-30).
What I've noticed is that synthetics seem to be the worst at controlling the noise. The only exception was PP 5-30, which controlled the noise nearly 100% of the time until I had about 3k miles on the oil. Almost overnight, it went from great to awful.
The two best conventional oils were Castrol and Shell.
The WORST oils at controlling the noise have been M1 and QS synthetic.
My question is this...what is it about synthetics that make them so incapable of controlling the noise? Are synths so slippery that they can't cling to the cylinder walls overnight? Has anyone ever done an experiment to test the "clinginess" of oil on metal? I figure a drop of various oils on a vertical piece of iron might give an idea of that particular property.
Anybody else out there with this same problem?
