Hi everybody,
maybe this belongs in "Automotive general topics", but I may need some coolant chemical response.
Here we go:
While changing coolant in my parents' car, a Ford Galaxy Van, I realized that there are some aluminum coolant pipes to be replaced. These aluminum pipes, together with EDPM hoses and steel pipes, are used to connect the rear heat exchanger. They are not sold individually. We can get a pipe kit that contains all pieces of hosing and piping required for the exchanger. However, Ford charges more than we think we wanna pay for it.
With seamless hydraulic pipes for example, we can fix it cheaper/better. Due to their location under the underbody, the pipes are exposed to dirt, grit, water, snow, ice, salt etc. Therefore, our choice would be galvanized steel hydraulic pipes.
Are these pipes usually galvanized on the outside only?
Is it advisable to use galvanized steel components in a cooling system, or are we better off using copper pipes?
How do aluminum and copper compare in terms of mechanical properties i.e. strength, ductility, fatigue etc.?
This is just another neglected cooling system being cured.
Thanks for all your input!
Regards,
R.Wolf
Here we go:
Regards,
R.Wolf
