Quote:
Quote:
On the other hand, my mechanic is telling me, that the pressure in the oil system is much higher than in the coolant system, so if the two were mixing, it would be the oil getting into the coolant system, not coolant getting into the oil system...
While the engine is running that is probably true, the oil is at a higher pressure than the coolant.
After you shut the engine off, however, the coolant is still pressurized and remains so for a while, while the oil is no longer under pressure.
Not to mention the fact that there are places in many engines where coolant can leak into the crankcase in a place where there is no oil pressure providing resistance. Eg. in a small block v8, coolant could leak from the coolant passages in the cylinder head, through a leak in the head gasket or intake manifold gasket, into the lifter valley. In a place like that, there would be no oil pressure resisting the coolant.
