Is there a summary of them anywhere? I was in Waldo Mart today and saw I think Motorcraft Syn blend for like $2.96 a quart- should I be using that in a 5000k mile oil change on an 04 Highlander? versus dino oil?
Quote:
blended using ~50% group III
Quote:
All of the Conoco_phillips syn blends: motorcraft, trop arctic, kendall, 76 are blended using ~50% group III syntheic base oils. Group III is a highly refined dino oil, that is hydroprocessed to a higher degree than regular grp II base oils. They have a supplier from Korea that produces the Grp III base oils for them very inexpensively. The CP syn blends have better cold flow and oxidation properties, but contain a standard additive package. They are a great value, but here is them kicker: CP is jointly controlled by the Venezuelan gov't, so when you buy their oils and gasolines, you are partially subsidizing socialist Cesaer Chavez, who hates america
Quote:
I just picked up a few quarts of Kendall GT-1 for 1.49 per quart.
Its a no brainer at that pricepoint. They had a 30 cent off per quart rebate making it 1.19 per quart.
