WIX 51087
Charlotte, NC
Part Number: 51087
Height: 5.477
Outer Diameter Top: 3.661
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 19
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 355
Max Flow Rate: 11-13 GPM
Nominal Micro Rating: 24
CAN SOMEONE EXPLAIN HOW THIS FILTER FILTERS....AS FAR AS % @ 10 MICRON
Can't be done AFAIK with just what's shown. That's a fairly liberal nominal rating (probably the single pass).
Also, your beta numbers typically won't fall into 10um, 20um etc. "They is what they is" type thing at give efficiency levels. One filter may coincidentally be at a 10um level at the normal %'s
