I have tried Rain-X in the past, and I hated the results.
The best results I've ever had were using paint sealant, topped by wax. Before I applied them, though I washed the windshield thoroughly, clayed it, washed it again, THEN applied the sealant, wiped down twice with a clean microfiber, applied the wax, wiped with another clean microfiber, and then buffed until I could no longer see any residue. The water just blew off when I drove.
Yes, it took a bit of work, but it was worth it. I should also add that I did not use the wipers even once as long as the water behavior continued, to make sure the wax and sealant were not worn away by the blades.
