Yes but back then (pre-SAE J300) the equivalent HTHS of a 20-grade was around 2.9 to 3.0, so it was a different 20-grade then.I have posted on here several times over the years about the use of straight 20 weight oils in pickups. When I was in grad school at the University of Illinois from 1969-1973, almost all the pickup truck owners I knew out there ran straight 20 weight oil year round. Those trucks ran into the 150,000 mile range regularly with no noticeable oil related engine problems. And they were NOT designed for that weight oil.So I always have to smile when I read posts like this.. No, they won't. I use 0W-20 VW 508 oil in my 2019 Passat and get great mileage and driveability.
The problem with the whole viscosity issue is people "want" there to be a single, direct answer. For example - 0w20 undoubtedly offers the best protection for my engine etc. Reality is viscosity and engines are somewhat dynamic. Most engines can be run on multiple grades within reason. Operating conditions vary, hp vary, life expectancy varies....the list goes on and on. I believe in what the OEM recommends. One could argue that is based on cost cutting, mpg and an operating life cycle of only 150k miles. Possibly. There is a range of possibilities that exist.
It's common to hear people complain of how manufacturers and blenders "hide" stuff, but HTHS isn't hidden at all. Sure some producers may not publish values (or may publish nominal values) but the grade gives a range, it's really a fool's errand to chase "higher HTHS" values within a grade. If you really want a high HTHS oil then go up in grade, you'll get what you want by doing so. It's also why approvals are important since many European approvals require a minimum HTHS as part of the approval process. You want a higher HTHS oil? Then get one with an approval that requires the HTHS you are seeking.Selecting oil by HTHS and ambient temps is a better determinator per your application than straight visc. Its a shame some oil manufacturers hide HTHS. As many have said, there is no "right" answer, it depends on your application and weather. IMO OEMs have gone the route to reccomemnd thin oils because they are usually synthetic, universal, and get better EPA numbers.
