Why on Earth are 26"x4" fat tires so expensive???
MO
Is there a rule for max width for a given rim width? I have a 29 inch wheel and assuming a tire clears the fork and frame can I go wider on my current rim?
Yes, ETRO standards have just been updated. You can check out the details here: http://engineerstalk.mavic.com/en/the-right-tyre-width-on-the-right-rim-width/
Note the chart is for tubeless. With tubes, pressure can be about 15% higher. The measurements are inner rim width.
You can put a pretty wide tire on a pretty wide rim. For instance, a 2.8" tire will fit a 29mm INNER width rim. If you have an old 29'er, it may have a rim ~19mm inner width, which was the industry standard forever... For those rims, I'd keep it to 29x2.4. If your fork is standard 100mm spacing and your frame was designed for standard 2.1" tires, about 2.4" is going to be the max before you'll run into clearance issues somewhere--frame/fork, even the front derailleur if you're using one.
MO
My bike is a 2012 Cannondale Flash 2 29er. The rim has a sticker for different width tire pressures with 2.3 being the largest. The outer measurement of the rim is showing at 29.5mm from what I can find online. Looks like a 2.3 is about as wide as I’d go as the front derailleur clearance is tight. The lefty fork has about a half inch of clearance. Thanks for the input. Next bike will hopefully be a single chainring full suspension rig.
Winnipeg MB CA
I'm sure prices and selection are better in the States, but when I bought the studded tires in March, 2017, the only ones in town (and I tried several bike shops) were the North45s. The 4.0"s ran $305 - $320 each, and my 4.8" (front tire only on my Surly Pugsley) was $380. Sales tax was on top of that.
So, two 4"s for my wife's bike, and a 4" and 4.8" for mine. That was an expensive day!
Yes, that's C$, but that's what I get paid in! :)
that's expensive! Even the days of silk tubular tires don't compare. But yeah, studded fat bike tires are next level "niche market"--add the Canadian juice on top of that and you're spending a lot of money.
Before the days of readily available studs, we would make our own with sheet metal screws drilled through the inside, and then hot glue Mr. Tuffy's in there to cover the heads. Absolutely insane traction on snow or ice. Was really glad to get these away and move to a climate where I'd never need them, though!
That's about the same I paid for studded Terrene Johnny 5 tires.
The joke about getting your kids into cycling and they won't have enough money for drugs definitely applies.
