What is a spongy pedal?
What do people mean by a spongy brake pedal? You know how you can press the brakes hard and the pedal is firm, but then you press it harder and it goes down say another 1/4" but the vehicle doesn't really slow down any faster. Is that a spongy pedal?
Ideally, when you press the brake pedal, it should feel hard as a rock. There can be a tiny bit of dead space at the top of the pedal travel, but as soon as the brakes start grabbing, the pedal shouldn't give. Pushing harder should make you stop faster, but it shouldn't make the pedal move. That way, you can control your braking with pedal pressure, not pedal travel. It's more intuitive and confidence-inspiring, and gives the best feedback.
Cars are rarely engineered that way, unfortunately. There's always a little bit of "give" in the pedal. Some vehicles have more than others. But the pedal should still be firm when the brakes are engaged, and you should still be controlling your brakes mainly with pedal pressure, not pedal travel.
If it's not like that, it's spongy.
And if pressing harder makes the pedal move but doesn't make the vehicle decelerate any faster, that's even worse. It's the opposite of how the pedal should work.
Ive noticed some vehicles take very little effort to push the brake pedal. The brakes work very well, the pedal is just very touchy.
On any car:
* Pressing on the brake pedal with the engine running but car not moving, the pedal should not go all the way to the floor.
* With the car moving, the brakes should lock up well before the point you reached in the first test.
Dear yonder varlet,
Air or water, unlike uncontaminated brake fluid, in the brake fluid is compressible. Hence the pedal giving spongy and indirect versus firm and linear feedback.
Originally Posted By: AVB
I don't think water is compressible. It will boil though.
Everything is compressible. The question is how much. Water has minimal compressibility, but not zero. Same with brake fluids.
Not sure if liquid water is more or less compressible than brake fluid at the relevant temps, though.
Originally Posted By: Kibitoshin
Typical vacuum booster behavior.
I agree, it could be flexing, but I thought he may be talking about his diesel. It should have a hydroboost.
You are correct, of course. The water in the brake fluid becomes compressible only once it vaporizes, which will happen under hard braking. Liquid water is measurably compressible, but it takes a whole lot of compression.
