In the case of high mileage oils, what is the purpose, and the difference? Is the school of thought behind this: (?) add more anti-wear additives, "seal conditioners" (which always sounds like a bunch of b.s. to me), and detergents?
Whatever the case may be, I would think that whatever formula a "high mileage oil" is, if it is made to serve "high mileage" engines better, which are more likely to have sludge, more likely to have wear which requires heavy anti-wear agents...wouldn't that just make them better oils, period? Including use in a brand new car (once properly broken in)?
Or, is there generally an accepted theory at work here, which refers to "additive build-up", i.e., too much zinc, too much (insert additive here). Can anyone shed some light on what the real deal is here?
