WD40 in gallon can
TN,US,Earth,Milky Way
My gallon can of WD40 states you should "agitate contents before using". When I put it in a clear dispensing bottle I can see a white cloudy substance in the bottom before shaking. What is that stuff?? Thanks. Later, Rick.
Hard to say. Isn't WD-40 one of those products that is comprised of a list of special, "secret ingredients", that stays locked away in a safe, much like the formula for Coca-Cola?
you might be right, but i would think someone would have done an OA by now.
[Linked Image]
I heard WD40 has lanolin in it, just like Fluid Film. It's an emulsion
The Unicorn tears are settling to the bottom and not correctly blended with the snake oil. As per directions, agitate to properly mix contents. I use obscenities to properly agitate things in my garage.
