Originally Posted by Talent_Keyhole
... Whether it is Walmart or Jiff Lube, leaving up to 20% of used oil of unknown quality should be a concern if your goal is to keep the vehicle for an extended period of time.
Unclear what alternative you're proposing to a normal oil change to avoid the feared residual old oil that's inevitably left to mix with the new. Totally disassembling and reassembling an engine to get out every drop?
Besides, the residual is normally less than 20% you're assuming. Toyota's specifications for my car, for example, effectively state the residual is 6%. Every manufacturer allows for residual oil in oil-change recommendations. Even when it's higher than usual, one can fully compensate by changing the oil slightly earlier than usual the next time.
