I don’t know about no good.
In fact, I’m not sure it’s that easy to find a syn diff oil that doesn’t have some level of LSD modification.
My understanding Was that the LSD additive affects oxidation stability. Something that is more of a concern with conventional lubes, less of a concern with syn.
A diff oil change is one of the easiest jobs to do, though the MB diffs tend to seize the drain plug pretty good, requiring a cheater bar. So to me it’s straightforward to just do it on a schedule with ATF, and do it time based on low mileage cars. The inclusion of LSD additive doesn’t bother me much at all.
All that said, I did read some anecdotal comments that conventional gear lubes cling and protect better in differentials. No idea if that is true. If it is, then running a conventional 80w-90 is a good choice assuming the climate allows. Conventional is what it was delivered with anyway...
