Really? Something must have changed in the K24 tuning on the CRV's. I've driven all generations except the newest ones and they're great vehicles - but glacially slow.My well maintained, barely broken in, K24W in my 2016 CRV EX just reached 43,000 miles and it's on its 5th OC of PUP. At 4,800 per year it's going to be a while before it gets into the high mileage club. It's nice to know that it has plenty of life left in it.
It idles smooth, but fully warmed up and in Sport mode, and it's looking for some open road or steep long hill to climb to show that it can deliver every one of the 185 horses it's rated for. It's like a sleeping sports car that somebody plopped a big box on top of it. Darn thing wants to get-up-and-go.
I wouldn't say the the K24 powered Elements or CRVs are glacially slow. Instead, I'd define their power as being "adequate". What I've noticed more than power is the brakes. With four people in our Element it takes noticeably more brake pedal pressure to slow the car (I use Honda OEM rotors and pads).Really? Something must have changed in the K24 tuning on the CRV's. I've driven all generations except the newest ones and they're great vehicles - but glacially slow.
Which also makes them great for the new drivers. You learn to leave some room to get to speed, not cut off others. The higher seating position, space all good. My son had a high mileage, hand me down '04 as his first vehicle. AC seized up needed repair so it was down for a bit and he got a Forte instead. Fixed the '04 and my daughter had it for a bit also learning on it until transmission went at like 270k. Ran great but needed something else. Sister handed down the high mileage '08. Daughter loves it everyday.Really? Something must have changed in the K24 tuning on the CRV's. I've driven all generations except the newest ones and they're great vehicles - but glacially slow.
It's probably just the transmission on the old ones. They just don't feel like they want to move. You have to really stick your foot in it to get it down shift once, I don't think I ever had my 2012 double downshift but I have a light foot.I wouldn't say the the K24 powered Elements or CRVs are glacially slow. Instead, I'd define their power as being "adequate". What I've noticed more than power is the brakes. With four people in our Element it takes noticeably more brake pedal pressure to slow the car (I use Honda OEM rotors and pads).
Scott
Try a 2016 in Sport mode with the engine fully warmed up.Really? Something must have changed in the K24 tuning on the CRV's. I've driven all generations except the newest ones and they're great vehicles - but glacially slow.
Great feedback! I’m debating using Valvoline Restore and Protect as my forever oil in mine.I've owned a 2011 Acura TSX wagon from new. Got a notice from Acura warning about oil burning due to problems with the low tension piston rings with a warranty extension and a recommendation to switch to Top Tier fuel. I was using Mobil 1 0w20 and following the maintenance minder but found I was down about a quart 6k miles after my last oil change in 2016 @ 70k miles. I changed to a 5k OCI and used Techron for a while and since then only Top Tier fuel. Replaced spark plugs and adjusted valves @ 90k miles and the cams and everything under the valve cover looked perfectly clean. Had no way to look down the spark plug holes. Oil burning increased to about 1qt every 4k miles until about 2022 @ 104k miles and then 1qt every 3k by April 2024 @ 124k miles. Extended warranty is long gone, but they wouldn't have done anything until I was burning 1 quart every 1k miles. That's when I switched to Valvoline Restore and Protect. It's now July 2025 @ 132k miles and I've used about one quart in the last 5k miles. Third oil change with Restore and Protect is due in a few thousand miles. Things seem to be going in the right direction.
Yes run a thicker oil instead of 0w-20 run 5w30. The oil builds pressure faster and it doesnt drain out of the VTC gear as much so it quiets down the rattle. I have two K24 powered vehicles and a k20. One of the K24's had the rattle until I moved to 5w30 and I haven't, except very very very rarely, heard it since.Has anyone with a K24 used any particular oil that changed anything with the VTC actuator rattle on start up?
Got my VCT actuator replaced under warranty and the problem never returned. It only happened when temps were below 20F. I’ve only ever used 0w20. I don’t know how well 5w30 would flow at those temperatures. I suspect the part has been improved.Has anyone with a K24 used any particular oil that changed anything with the VTC actuator rattle on start up?
