Valvoline R&P 0w-20 10.9k mi; 2022 Toyota Camry Hybrid 2.5L 120k mi
10.9K mile sample of Valvoline R&P 0w-20 with a FRAM Synthetic Endurance FE4967 oil filter in my 22 Toyota Camry Hybrid 2.5L. Mostly highway/interstate miles with some city and rural road driving. Car now has 120k miles on it. Only thing changing for next is will be using the new Mobil 1 oil filter as the Fram Endurance is becoming harder to find in my area.
Thats ~0.37 ppm/1k mi of Fe… holy cow that’s crazy, even for Toyota IMO. I just crossed 123456 miles on mine, may switch to this in the future. It’s dual-injected, which mitigates carbon buildup on the valves nearly completely. This engine could be a 500k mi engine, easily. It’s a simple engine with no belts and easy maintenance. Plus, the eCVT is bulletproof.
or 0.74.... look at the phosporous numbers and then tell me how confident you are about any elemental number in there. How can the phosporous jump to twice the amount in 4k miles. Especially since phosporous is linked to zinc, both come from the same molecule and the ratio is fixed.
uoa is not precise enough to make such claims.
It's a very good oil, but it's not responsible for the wear numbers on this sample. My bet is on the 700 miles per week of mostly highway miles. Any decent oil would produce similar wear numbers in the same engine under same driving conditions.
It’s still ~0.37 ppm of Fe per 1k miles.
The comments on engine lifespan weren’t related to their UOAs, it was just a general observation based upon my experience with the engine. I’ve followed dnewton3’s comments on UOAs along with others, no claims made here.
I would agree, any decent oil with API SP/SQ would most likely provide similar results. There’s a guy on Reddit who had nearly 500k on this same engine, strictly highway.
I would agree it looks really good 👍
I'm all so curious to know if there's any top up oil, how the filter looks, and if the OP was running it just because or trying to clean things up?
No Top off oil was added, level never lowered from initial fill. I talked to LSJR at PRI in Indy last year and talked to him about a video that he was gonna test VRP in his wife's Sienna. If the oil is good for cleaning a dirty engine, why would it not just be just as good for running in an already clean engine. My next interval to test is gonna be 12k to 12.5k, I'm already 3000 miles on the interval.
Sample AAB-0322 what was the Valvoline product used?
Both Valvoline Samples were Restore & Protect. I'm not a fan of the new Speed layout on the report that removed the oil brand variety category, because of now using Magiclink vs the old google form sheet.
I applaud you! Many have been wondering about the long drain capability. Any chance you're going to do a TBN? Thank you for the report, very insightful.
I feel the same way in regard to running it long term.
