Valvoline Advanced full synthetic 5w30, Tuned on E85 5.7L HEMI, 6000 mile OCI, 130k on engine
Palmdale, CA
Tuned and running around a 4.6 sec 0-60 time. E85 used as the only fuel for the run..
Run HARD… it sees 6000 rpm every day..
Little disappointed it sheared to a 5w20 but probably to be expected on e85.
Add pack looks great on this valvoline!
Your title says 5W-30 and your report says 5W-20 I believe the 5W-30 is correct. The 100C looks to high for a 20 weight.
But good numbers and I like that flash and the TBN.
Those are some pretty impressive results (TBN) for use as hard as you described...
🤔 Does TBN wear down faster simply due to Hard Driving? 🤨 I don’t think so.
There’s plenty of UOA of Track Used vehicles with tons of TBN left.
