- Joined
- Sep 26, 2010
- Messages
- 9,807
From an ATV forum that I frequent (where there are the typical arguments about synthetics versus conventional--albeit far less factual).
This particular thread is discussing rob bearing failure due to the use of synthetic oils. These ARE taken out of context, but should be enough to understand the point.
Thoughts?
-- A good question would be, why does synthetics cause the Rod bearings on the crank to go out...
-- From my experiences and motors Ive rebuilt that have used synthetic like mobil1, amsoil, royal purple. the wear in the motor isn't caused by bad oil. I believe the oil runs too thin when hot and can find its way to cavitation, or find it's way past the oil bearing on the left of the crankshaft.
-- I had a guy JUST LAST WEEK!! member from on here. he came up to buy ANOTHER crankshaft. his machine was NOT abused, its stock and in amazing shape. he didn't head the warning about using royal purple and it cost him another crankshaft...
-- Bottom line is... after you break an engine in and switch to whatever oil you are gonna run... it's more harmful for you to switch oils multiple times, than it is to stick with whatever oil you use...
-- Don't go from conventional oil, to sythetic oil... and then expect to go back to conventional without a problem. That's widely known. Maybe that was the issue with those that tried synthetic.. I don't know. I can only say that my ATV has been fine on Royal Purple...
-- Is it the multiple viscosity synthetics causing this? I had castrol sytec in an LT1 years ago, and when i tore the engine down, I found wear and an oil that looked like it was half the weight of the oil I put in. 0w-40W oil is like having Wd-40 at start up to warm up in my opinion. I could believe that would turn a crank bearing....
Thoughts?
