Using Lubro/Liqui Moly Motor Oil Saver with an HM
Italy
Is it a no go or can I use the product with my current fill of Valvoline MaxLife 10W40?
The car burns oil. Currently using the Valvoline and it seems to have only burned a minor amout at 1000 miles and I was wondering if I can fill it up to max when needed using the Motor Oil Saver or is it just too many seal conditioners to make it healthy?
My experience is dont, "Conditioners" is just a nice word for "seal swellers" IMO, once the engine seals get used to that bloated shape, the minute you stop the treatments it gets worse than it was before. Just stick with what your doing or fix it.
If your sure its just the rubber valve seals not the rings, thats a cheap job relatively
Some seal swellers like White Shepherd claim a permanent fix. Just sayin.
Has it happened in your experience, or is it only an IMO?
I think I've read that was only a myth.
What was a myth? Seal swellers? Conditioners? Explain
In the M1 HM FAQ seal "swellers" are mentioned. In the official Product Data Sheet the word "Seal Conditioner" is used. All brands seem to be intentionally unclear how they do it.
I think seal swellers ARE used. My experience using this oil on the Camry in my sig:
Symptoms:
Bad valve seals, blue smoke at startup, excessive oil consumption. Oil pan, valve cover leaks.
Results:
First M1 HM OC - no difference in oil consumption or leaks. Likely why many people bail. Second OC - WOW, no leaks, oil consumption went down to almost nothing. Took about 10k to see results, and they were dramatic.
decided to go off M1 HM and experimented with straight M1 5w30, even M1 0w20. As before, the first OC was fine, the second OC was awful, the leaking and oil consumption came back even worse.
Went back on the M1 HM again, first OC was bad, second good again. Now I'm staying on it.
So in summary I think there was a delay in effectiveness while the seals "swelled". If it were conditioning alone it should be more permanent, not go away so fast?
Good to know, thanks. Will go check that out
