I'm running the factory tire size for my truck, although a different make/model tire. Door jamb says
Front: 29 psi
Rear: 32 psi
Drives fine and tread wears evenly, but feels mushy and "heavy".
I did the chalk test at 34psi all around and as far as I could tell, the tread was still evenly applied to the road surface.
For the rears, no biggie since it's +2psi, but this means the fronts are +5psi from the mfr recommended setting. Seems a bit odd?
Although, to be fair, I did add an off-road push bar to the front bumper and sliders/steps for the cab. Around 250lb of added weight over factory. Would this factor in?
Front: 29 psi
Rear: 32 psi
