I finally replaced my 2000 MPV coolant last weekend. Yes, it was over-due according to the maintenance schedule (36 months or 45000 miles). However that did not bother me that much but the coolant replacement procedure (from the OEM shop manual):
1. remove the radiator cap
2. un-screw the radiator drain plug to drain the coolant
3. flush the radiator with water until the water runs clean
4. screw the radiator drain plug
5. fill-in new coolant with the appropriate concentration
6. tighten the radiator cap
(a few more steps to purge the air trapped)
The problem was step 2 only drained 4.5 quarts of old coolant, out of a total capacity of 10.8 quarts! What that means is there still is about 60% of old coolant in the system. I seriously doubt that kind of mix will provide proper corrosion but what do I know. Interesting thing is that is exactly the same procedure I have seen in one dealer's ads for $59 the other day.
Since I wanted to replace the old Mazda coolant with Toyota red and no where in the manual I could find any indication of an engine block coolant drain plug, my only solution was to fill with distilled water and did the drain procedure repeatedly to dilute the old coolant further. I did a total of 5 times, which I calculated should have cut it down to 8%. To make thing complicated, I had to add some new coolan even after the 4th drain because I needed 5.4 quarts of new coolant in the system and that exceeded what it could take (4.5 quarts) per fill-up. Some math was needed to find out the exactly amount of coolant at the 4th drain since 40% of it would be drained out immediately in the 5th. Talking about fun for the Sunday afternoon.
