This is the reason why more than ever it's important to preserve paint thickness and why even a just a few compoundings can significantly reduce the thickness of paints. Early 90's I remember some OEM paints were thick enough to wet sand safely to remove orange peel. Talking 250-300 microns plus! Those were the days.
http://www.autogeekonline.net/forum/wet-...-thickness.html
Now with some paints you're down to 90 microns. That is thin. No room to wet sand and you better have a paint thickness gauge if you're a professional or are advocating or advertising getting paint "perfect". Once you get rid of the defects it's impossible to tell how much more paint you're removing without one.
A micron or two here and there didn't mean much when you had 200 microns of paint. Now a micron or two can mean the difference between excellent paint life and peeling clear. This is especially true of the more advanced clears with harder top layers than bottom layers. Wear them out and watch the paint life drop to less than the car's payment plan. Yikes!
