Synthetic for 02 Acura MDX
Anchorage, Alaska
The 02 MDX calls for 5w30 and right now I have PP 5w30 in it, should I stay with PP or switch to something else? Also would running 5w20 be a better choice, I live in Anchorage, Alaska(winter is -5F to 36F and summer is 40F to 86F)
I would consider a 0w30 but they dont have the M1 0w30 at my wally world, but would PP 5w20 be good for the MDX.
I also heard that PP 5w20 will give me better MPG(Right now Im getting 13MPG instead the actual 17MPG city I am suppose to get)
Ted, try the 5W-20 and if you have no consumption problems go ahead and use it. I would go back to 5w30 in the summer. The only reason I say this is because I don't believe Acura recommended 5W-20 for your car.
0w-20 or 5w-20 would probably work fine in that engine.
Are you sure the fuel economy drop isn't caused by the cold temperatures?
Originally Posted By: TedSexington
could be but during summer i get 16.3 MPG when i should get 17 or 18
Could it be your driving style? Do you have a moderate to heavy foot?
How many miles on the vehicle?
At first they recommended 5w30 then I think by 04 or 05 they speced the 3.5L MDX to 5w20 for some reason
Its probally to improve there "overall" fleet MPG (CAFE requirments).
Either oil weight will work GREAT.
Whatever your oil cap says, I would normally recommend.
Don't think I drive hard, I usually keep my RPMS under 2 1/2 and never over 3.
I have 100718 miles right now
It's due for the 105k service soon.
Timing Belt, Timing Belt Hydraulic Tensioner (not required, but very common to be found leaking, so I'd definitely replace it), water pump, drive belt, spark plugs and coolant. Then, the spark plugs should be replaced and the valves need to be adjusted. Total price should be between $1200 to $1600.
Anyway, the new plugs and the valve adjustment should help your fuel economy. The valves are known to get tighter (not looser, which is why the adjust only if noisy recommendation is bunk) so you won't notice it. Once you have the 105k service done, that should help your fuel economy some. Maybe not 3-4 mpg, but definitely some.
Supposed to get? Your drive route is your MPG. The change in oil weight would be less than 1 mpg difference. Ethynol reduces MPG 10%.
