Hi,
Wife's MY19 Suzuki Vitara had a very hard ineffective brake pedal on Sunday. That issue can come intermittently and is very rare, but imagine it popping at the bad place in time...
Then we reminded we had a recall letter from Suzuki about this, and we forgot to turn into dealership to sort it out. I believe it's this recall campaign "97G5" but not exactly sure.
This is the recall letter we got. It essentially says they some vehicles are affected by a faulty vacuum pump check valve that could potentially reduce braking assist and present a stiff brake pedal.
While the car is booked in on Thursday, I'm not sure I'll get a positive outcome first hand, since the service advisor told me they have to check first if the part is faulty or not. I went to the parts counter but the part didn't seem to be in stock. It can have a two weeks delay for delivery if ordered. Saw this part number 51280-61M00 for a price of €247
So I got home and started searching the web.
Found pics with the Bosch reference written on the part, 0265005336 -- and indeed looked on what would have been the check valve for me, I see this.
Amazingly this is also found on McLaren 520/720 around 2020. but how much of a sensor it is, and how much of a check valve it is? Do you think there's a check valve on another location? In the vacuum pump itself?
I've stumbled upon threads of other cars where this vacuum sensor could do the exact same thing: give a hard brake pedal to the point where you can't realistically break, and I understand it does something to the ABS pump and that's why it can get the pedal impossible to press.
While I understand it's not a good idea to mess with braking system, is there a possibility of running brakes and ABS without the vacuum sensor, fitting a dummy/emulator? saw this on trucks for hydrobrakes conversions but wondering. How to get rid of that point of failure?
