Super Auto of2500x (57045) cut open
Phoenix, AZ
I picked up these Super Auto oil filters for less than $2 each and they seem to be of good quality (supposed to be equivalent to 57045 filter) I have searched the internet and cannot find any info on these. Has anyone heard of these or know who makes them? The media is 2.75" x 46" and has 49 pleats. I have cut this open for your thoughts, thanks for any input..
Katy, Republic of Texas
That can shape looks familiar, but can't remember where. What is the country of origin on the box? Not a Wix (wrong base plate and center tube), or Fram (Fram does not use louvers or coil springs). It may be a Champ filter (but don't think so), and also don't think it is a Purolator either. Purolator uses leaf springs in most of their filters, not coil springs. If I could see the bypass spring I could tell if it is Purolator. It just may be a generic MiC filter (although those usually have a "Leak Tested" stamp on them, as well as a normal date code, and usually don't use louvers either). shrug
PNW
Originally Posted by PimTac
The media looks like recycled cardboard fibers. 👎🏻
Yeah, the media looks a bit odd.
The Old North State
The use of coil compression spring makes it look similar to the China coo OFs posted here. So without more information, just a generic filter of that origin. And though Puro is mentioned a couple times this thread, never seen a Puro US spin on that uses a coil compression spring. The bypass spring housing looks oddly long in the one pic. It does say "removes 99% of engine oil impurities for superior engine performance" Well, there you go. laugh
