Stored oil life
wichita kansas
I still have some PenZ PP from about 07 and 08 that I haven't used. When I bought them I had three vehicles that I was doing oil changes on, but now am down to 1. It is kept in the garage, but it doesn't freeze in there. How long should I expect it to still be good or does it really ever go bad?
I guess it depends on conditions, but im still using up torque power stuff that is dated 06 and there is not settling or anything. Personally i would not be worried about using anything that is even 7 or 8 yrs old if it is still sealed and has not been sitting out in the weather. Just me but if it can last a year in a crankcase, it can last a long long time sitting in my shed sealed up. I have found old wolfs head stuff in my grandfathers barn a few years ago that still poured and looked like new and i would hate to guess how old that stuff is. I used it as top of oil for my old Toyota truck.
I date and price mark all my stuff when I put it on the shelf. Still using some Mobil 1 I purchased in 2000 for a little used vehicle. I've heard rumors of additives settling out in some older oils, but have yet to see it in any of mine.
Even if they do settle out a little, i believe you can shake them up and mix them back up. Has anyone ever stored oil and have had it go bad in some way. Maybe condensation or something?
Originally Posted By: bkbenjy
http://www.carbibles.com/engineoil_bible.html Scroll down to the bottom of the page. It says 3 years
I wouldn't believe much in that article. 15W40 needing to be changed more often?
"Mineral Characteristics
10W-40 15w40 Basic protection for a variety of engines
Oil needs to be changed more often"
Look at this gem: "Well most of the diesel oil specification oils can be used in old petrol engines for cleaning, but you want to use a low specification oil to ensure that you do not over clean your engine and lose compression for example. Generally speaking, an SAE 15W/40 diesel engine oil for about 500 miles might do the trick. "
Over clean your engine? Everyone, QUICK - dump your PP NOW, before it's too late.
I've used 6-10 year old HDEO oil without issue. In fact, the next change on one of my Jeeps will be with Chevron Delo 15W40 from 2002. I haven't a worry in the world.
A little off topic - This article states: In 1996 the EPA forced that to be dropped to 800ppm and then more recently (2004?) to 400ppm - a quarter of the original spec.
IIRC, the SM spec limited ZDDP to < 1000 PPM. I know I've seen SM VOA's with higher than 400. Anyone?
I called Shell Canada and they told me 7 years would be no problem in a cool/dry/dark storage like a basement.
