Sludge inside a crankshaft
If you omit cleaning the crank oil feed holes, you are asking for trouble. Even if you shortcut it by not drillning out the plugs. you should use several cans of brakeclean or the like & push the "straw" into the holes- repeat until clean. Too much trouble? It's your motor...........
Sludge generally is caused by the acids created from poor crankcase ventilation. Other reasons, too, I'm sure
