I've always done the maintenance on my close friends cars, they buy the stuff and lunch and I work away. In November, while I was doing a transmission service I asked scotty if he had ever had his diffs in his jeep done and he had no clue so I told him we should put that on the list. He's coming up on 170k mile on a 98 wrangler. He's always done the maintenance that the jiffy lubes he used to go to told him he needed so he's done his best to care for this car and even after all those miles, in the 5k we do his OCI's at it never consumes enough oil to warrant adding any and his transmission still runs beautifully. Worst thing about the car is a whiny PS pump.
Anyway, I was wondering if there would be more harm than good done by taking the covers off the diffs, cleaning the interior, and refilling them with new fluid OR since theres a great chance the fluid in there is 14 years and 170k miles old it would be safer to leave it in?
Also, is there any way to quiet his pump down? In November, I drained as much of the P/S system of nearly a quart of fluid and replaced it with ATF fluid. I used Lucas ATF fix because I wanted all that detergent in there. It's another system that possibly never got serviced and I wanted to clean out any possible build up. It'll get reflushed and filled with a quality P/S fluid when I do the diffs. The Lucas definately quieted it down but it still whines, will actual P/S fluid quiet it down even more, or stick with an ATF?
Thank You in advance for any and all suggestions in advance.
Richard
Richard
