This is my first analysis on my 23' Hammond Challenger MK II Boat.
Schaeffer 10w30 PAO Blend
360CI SBC 425 HP 72 MPH on Gaffrig Gauge's
256 Hours on Engine 50 hours on oil
Wix 51773 Oil Filter No Air Filter
Oil Cooler @ Powersteering Cooler
Boat is primarily used for crusing but see's WOT alot also! Oil temp stays at 175-190 under normal crusing but will raise to 220 but never over 230 degrees after 4-5 mins of WOT at 70+ mph.
Schaeffer's Analysis
Copper 85
Iron 54
Chromimum 0
Aluminum 7
Lead 16
Moly 108
Phos 885
Zinc 995
Mag 52
Calcium 2108
Antifreeze 0%
Fuel Positve Does not give exact amount
H20 0%
Silicon 10ppm
Visc 8.3 cst
SAE 20 W
Oxi 2%
Nit 5%
Sulfur 34%
Well I would appreciate some opinions on this UOA! Schaeffer's stated the visc reduction was due to the fuel dilution and that high copper was more than likely from the oil cooler. I'm definately going to a thicker oil next season, probably Schaeffer 15w40 PAO Blend or Amsoil 15w40 AME HDD and Marine. Wear numbers have to be better with a 40w instead of the 20w in there now.
[ September 29, 2003, 05:18 PM: Message edited by: Ryan00TJ ]
Copper 85
Iron 54
Chromimum 0
Aluminum 7
Lead 16
Moly 108
Phos 885
Zinc 995
Mag 52
Calcium 2108
Antifreeze 0%
H20 0%
Silicon 10ppm
Visc 8.3 cst
SAE 20 W
Oxi 2%
Nit 5%
Sulfur 34%
