MolaKule
Staff member
Originally Posted by PimTac
Originally Posted by MolaKule
Originally Posted by racin4ds
Ignore the naysayers on here... they still think oils come off the shelf with top notch additives and can't be improved upon, all for $19 a 5QT jug.....
LG and Archoil are both great products. I also love Lubrimoly M0s2!
I am still waiting for anyone to tell me what chemistry the formulators have left out of formulated, finished oils that require LubeGard BioTech or RLI BioSynXtra or others.
In the case of Lubegard Biotech, it must be that fancy rapeseed oil they put in it.
They don't use Rapeseed Oil. They use a special transesterified version (ester) of rapeseed oil. The LXE ester was developed to replace the Sperm Whale esters used in older ATF's.
And what tests have shown their LXE esters to be superior in friction modification with respect to current FM''s?
Originally Posted by ILI
A new oil may not contain sufficient additives such as ANTI-WEAR agents or ANTI-CORROSION compounds even though it passes all the tests. Furthermore, these protective compounds are depleted when the oil is in service.
What ANTI-WEAR agents or ANTI-CORROSION compound additives are in insufficient quantities in modern finished oils?
