Replacing brake pedal rubber
007
Clermont, Fl
I recently noticed that my brake pedal rubber with the disc brake disc in the middle had cracked from top to bottom on my A body. I bought a new set of replacement pads which came with the regular pedal and emergency pedal rubber. I am sure it will be easy to get the old stuff off but is there a secret in getting the new stuff on?
Canada
Should just slide on. You might want to use a bit of water or silicone spray as a lubricant to aid the process of stretching the pedal rubber to fit onto the metal, but make sure that you clean any lubricant off of the pedal surface once you're done.
iowa
Originally Posted by Trav
Grab the wife's hair spray. Seriously.
Exactly! Works good for motorcycle grips, etc. I'm still trying to figure out how to get the hair spray off the drivers side window of every car she has had. I've had to use a razor blade since I didn't have the right stuff.
North Carolina
Lacquer thinner should do it. A lot of hairspray is lacquer, at least the aqua-net i used to fuel my potato gun was.
sw ohio
Aqua-net was the good stuff. Worked better than other brands. Still available?
