Reman steering rack 09 CRV
PA
All: I think I know the answer but is there a decent reman option? I can't see spending 1k on a new Honda part. Even the reman Honda options are expensive and don't include tie rods. Should I look at Napa or is that a lost cause as well? I have a small leak at the boot and air seems to be reaching the reservoir. (Even after replacing the hi/low gaskets and even the pump). Thanks
Maryland USA
Air reaching the reservoir - I recall there were some o-rings that frequently failed, causing noise and air leaks. Has you looked at the o-rings yet ?
Ohio
I have a 2007 Honda CR-V (same gen as your 09) and got the rack replaced last year after an accident. My mechanic used a Napa unit, zero issues or complaints. I think you'll be fine going that route. Only power steering issue I have had was a leaky return line but that's my own fault (long story short my return line came unsecured from it's clips and my axle rubbed a hole into it lol)
Chester11
PA
awesome...thanks Trav...I'll give them a call. The leak is not bad yet - so I may put this off until spring.
MA, Mittelfranken.de
I have done quite a few on Odyssey vans using JAC, they send you all the O rings and bits you need plus a return shipping label for the old one. They are a small family business who takes care and pride in their work, the racks are always centered and adjusted properly and work perfectly. I have had them build some real obsolete off the wall stuff no one else could do without a core (JAC found a good clean one, it took a while but they got one), it came out perfect.
