Reducing breakaway torque and friction heavy lube
KC AREA
purely a theoretical question .
Suppose a synthetic base oil with GL additives showed :
40 degrees C .......... cst above 7000 ( not a typo )
100 degrees C .......... cst above 300 ( not a typo )
pour point of 5 degrees F
Density of .897
Suppose your goal was to retain as much of the EP/AW protection of the original product as possible ,
while reducing the breakaway torque as much as possible .
At the same time total viscosity needs to be reduced appx. 40-50%
You know , the high film strength , low parasitic drag , holy grail of lube ...
Slicker than snot , tougher than nails , and all that .
Am I correct in calling these " Friction modifiers " ?
Honestly I'm a little confused on the whole friction modifiers issue ,
ATF vs. LSD FM chemistry being completely different ?
Enlightenment appreciated , what have I missed ?
start with a 0 grade bentone grease.
made with low vis PAO for a low breakaway torque or alow vis base oil star away from high vis oils they are to "sticky" use a low vis oil and ahigh amount of thickener bentone or silica.
bruce
thin with kerosense or such
bruce
""ATF vs. LSD FM chemistry being completely different ?""
Not a good FM for gun use in slow moving, low heat, low pressure applications stick with Fatty oils or sulfurized fatty oils
or phosphoric esters etc
bruce
paratac will not add much to the drag and will help with run off
stay away from resins and wax to sticky as in glue
pick a good AW system (sulfur fatty) and then build up body with gelling additives to consistancy you like. lube has to stay put to do anything and a lousy lube thats stays put is better than one that washes or runs off after a few hours unless you want to re apply all the time depends on what you want to do.
I use a bentone gelled PAO of low vis gives LOW breakaway torque (there is a bearing test for that)
Then use a low temp activated Friction modifier as in lowers friction
Seems I was headed in the wrong direction ...
Thicken the thin stuff , not thin the thick stuff .
Would sulfer ester be an example of the low temp FM mentioned above ?
Thanks for the advice !
