Radio, Instrument panel, display, AC cutting off
East Europe
So I had the radio cut off a few times 2 months ago. Read up and installed a ground wire from battery - to chassis. Problem solved. Until.. Yesterday I got to do a 100 mile trip. Radio, Instrument panel, display, AC cutting off started on the last 10 miles. They come back on, stay on for a 2-3minutes(sometimes) and then go out again. Car drives normally otherwise. Drove 5 miles today and re-tightened any ground cable I saw. Still same thing. And airbag warning turned on. What could be causing the issue? I want to run a 4 AWG from alternator to battery + to try to solve it. OBD II sees voltage dropping from 14.4 to 12.8V, but this is only OBD module voltage. Still tells me alternator cable is loose or worse.... Any input appreciated.
East Europe
So far it looks like the fuse box ground was loose, contact sprayed it and so far, so good. 4 miles with no incident. A buddy mechanic said not to mess with battery plus to alternator.
MA, Mittelfranken.de
A common upgrade on many Euro cars is a 2 or 4 AWG alternator to battery and 2 or 4 AWG from battery to fuse box depending on alternator output and options the car has and 1/0 battery to starter. VW got all sinister with very light cables that caused all sorts of gremlins, doing the upgrade really straightens them out to say nothing of the much faster cranking in cold winter temps.
