Originally Posted By: Hemi426
Well, I can't say for sure. It seemed to drain slower and just looked to have the viscosity of say a 10w-40. You know how 5w30 drains like thick water when at full temperature at an oil change? My brew just looked thicker and seemed to drain slower. Maybe it was just my perception of things.
I have to say, sometimes the eye sees what we want it to see.
If your Oil drains out a rust color, it means Blown HG to one.. Additive use to another.
If it drains out Black and watery, its supposed to be fine.
If it drains out in Chunks (!) its one person's "Sludge-cleaning" with who and God knows what, .. another person's "Dying engine."
Mixing Conventional with Synthetic is SUPPOSED to be fine, though a lot of people dont do it. They also say that the Oil will "Pump at the grade of the heavier Oil" but that makes little sense, if the heavier Oil is 1/5, 1/6, 1/4, 1/8th the sump.... ?
Im convinced that if one finds an Oil that works, they should continue to use it. If the Oil happens to be a Mix of grades, kinds, to get optimal properties of both, you SHOULD generally have a result somewhere in between the two, and sure some will say "Throw a quart of MMO in there to better help the cleaning" why not.
My reading leaves me no less than -3- oils i like, M1 being one of them. Seems it works well, yet differently. All hype posts excluded regarding 1.8Ts, which are "Known sludgers" as well as some others (Saab 9-3 Viggen, etc.)
OP.. Desired result of mixing? Or mixing just because its low? Either way.. its fine.
We promise. Cross our hearts.....
