PQIA HD Tests
MD
Originally Posted by MolaKule
Okay, lets try this again without a link to my business email. blush HD Oils Tested
Still loving the T5 as a solid consistent performer. Delo moly is looking nice too, though!
Indiana
Delo BORON too.....
N.H, U.S.A.
I don't use this service category, but I'm a card -carrying Chevron Hater ( as their products have NEVER performed well enough for me) and it is great to see that Plain-Jane Rotella T4 had a VI of 140 beating DELO IsoSyn Advanced VI of 136 and it's poor ZDP showing smile
MS
Chevron makes consistently good products though.
Central Florida
Originally Posted by claluja
T4 and T5 look good. Surprising how low the P and Zn are in the others. Thanks for posting.
And they sell this oil in 2.5 gallon jugs (10 quarts) and sometimes very good deals on it. I'm going to run this in my Chevy.
AR
High ZDDP has given way to many other additives that don't show up in ex. blackstone VOA's More ZDDP does not equal 'better'
MD
Does less ZDDP offer any benefits, other than cost savings for the manufacturer? Not picking a fight here, just wondering what these other additives are that aren't showing up in Blackstone reports?
AR
Antimony and titanium for example - both more expensive to add than Zinc.....Boron you can see in UOA's Problems arising with 'high' Zinc are mostly with the exhaust after-treatment systems, where they cause more deposits in the DPF etc. systems.
New York
Shell dropped API SN from most of the Rotella flavors. The others did not and have chosen to abide by the lower P limits of SN.
Cincinnati, OH, USA
In a newer, emission controlled diesel (or gasoline) engine, yes-but in an older diesel or higher performance flat tappet, high lift & duration cam gasoline engine-my vote is a resounding NO!
Carolinas
What makes an oil better then? How many permutations are there on different additive concentrations? When comparing T5 to T6, it appears that T6 has more antiwear additive. Does that make it better?
AR
better and higher quality base oils....better additive packages, (ZDDP is but one of many, many anti-wear additives).
Carolinas
[quote=tundraotto] More ZDDP does not equal 'better'
I have often wondered why there aren't individually packed additives that you can add to your oil; like in a chemistry class, or a cocktail bar.[/quote]
MD
Gotcha. Blackstone does test for Titanium. It showed up in a VOA that I ran on Delo semi-synth.
AR
Originally Posted by Mr Nice
Some Mustang owners with 5.0 Coyote engine say the extra zinc in Rotella T5 and T6 got rid of the engine ticks. Maybe the extra _____ helped them?
Like the Castrol Magnatec or Rotella Gas Truck oils quieting the valvetrains.....was it the ______ in them that did it?
South Carolina
I've noticed in my Taurus that it runs quite with rotella gas-truck. I believe its supposedly a mix of GTL and group iui oil. Ots addictive package has a good dose of moly as well. Sddp seems average in it.
