Put in a remanufactured motor from a reputable engine builder, one that I have purchased and used an engine from before. 350 Chevrolet truck motor, TBI. Took our time, thought everything was being done correctly, but something is wrong. Upon startup, ran great, sounded good, but noticed no oil was going to the top of the motor (no flow visible in the filler cap hole). Removed valve cover enough to get a better view and this was confirmed. We had used the drill-driven oil pump primer before hand, and it was showing oil pressure on the dash gauge, and primed the motor by turning it over till it showed pressure on the gauge (cranked it without fuel pump fuse in place), then started it up. Symptoms are this: even after running for about 2 minutes, no oil is on the valve springs or rocker arms etc, indicating lack of oil to the heads. I had been told by a more knowledgeable mechanic friend that possibly the thick assembly lube was plugging up the inside of the pushrods, and that if it was ran shortly, it may warm up that assembly lube and dissolve it, enabling the oil to flow through. We ran it shortly, about 2 minutes or so, and it sounded great, until...still no oil flow to the top of the head was visible, we were about to shut it off and regroup, and... a noise appeared. It was hard to pinpoint the source of the sound, appeared to be coming from under the truck. After a frantic brief search for the source of the noise, we shut the motor off. It sounded like someone was banging on a heat shield, it was pretty loud. All exhaust bolts are tight, and the noise was not there till after running it for about 2 minutes or so. The pressure gauge on the dash showed 55 psi oil pressure at idle, although peculiar to me was that when the motor was revved, it did not move up or down, but that may be a minor detail.
I am very worried that whatever just took place costed me a brand new motor, to the tune of $1300, which is hardly a good thing obviously. Any ideas or helpful advice would be greatly appreciated. This has never happened to me before.
