Owner's manual says ATF M-III, M-V, or equivalent. Since it's not a shifting transmission I'm dealing with, does it matter which type of ATF I use? Could I use the extra quarts of Honda ATF-Z1 I have sitting in the garage and expect good results? Or should I just get a synthetic Mercon III or V and be done with it?
With the turkey baster method, should I gradually replace the fluid all at the same time with the car running? Or is it ok to do a little a day 'til it's done? My concern is mixing of different fluid.
I have 37k miles on my V6, and a serious itch to change the P/S fluid whether it's too soon or not...Mazda says it never needs changing, but I disagree.
