Originally Posted by paoester
krismoriah72, Valvoline Maxlife Multi-Vehicle ATF is not officially OEM-qualified (Ford). Its probably OK. Valvoline says go ahead and put it in any Mercon LV or Merconv V application like yours.
(If you have the Aisin F21 6-speed automatic they were using in some 2012 Fusions that year, you need a WSS-M2C924-A spec transmission fluid, not the Mercon LV).
I'm guessing you have the Ford 6F35 6-speed automatic, which calls for Mercon LV.
I would just use Motorcraft Mercon LV for a 6F35 tranny. You can get it pretty cheap at autoparts stores and I think walmart has it. Then you have the same stuff Ford used in durability testing, so its good.
If you have the Aisin F21, then "Motorcraft Premium Automatic Transmission Fluid" is the one you want. Not sure if you have to go to a dealership for that.
Or, you can just trust Valvoline and get the MaxLife for about any non-CVT automatic tranny on the planet.
I would go with Valvoline. There is a reason why Valvoline is recognized world-wide brand associated with high quality.
