From Amsoil's site:
2005 DODGE NEON 2.4L 4-cyl Engine Code S Turbo
FILTERS
Oil Filter......... EAO34 AMSOIL Ea Oil Filter
Oil Filter......... 51516 WIX 51516 Oil Filter (O)
Air Filter......... 42384 WIX 42384 Air Filter (S)
Fuel Filter....... NS
Trans Filter..... NR [1]
Cabin Filter..... N/A
1. Manual Transmission
NGK PLUGS & WIRE SETS
Plug................. IXIRIDIUM LZTR5AIX-13 NGK2314
Plug................. VPOWER LZTR5A-13 NGK4306
TRICO WIPER BLADES
Blade Class Driver Passenger Rear
NEOFORM T16220 T16190
EXACTFIT T221 T191
WINTER T37225 T37190
OKTANE 22 inch 18 inch
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0w30 Motor Oil
SAE 5w30 Synthetic Motor Oil
SAE 5w30 XL Synthetic Motor Oil
All Temps......5w30
Manual Transmission,T850.....AP4[1]
Synthetic Automatic Transmission Fluid
Manual Transmission,T350.....AP4
Automatic Transmission.....AP4
Fluids
Power Steering Fluid.....AP4
Brake Fluid.....HB
1. Use 4oz Of Mopar Limited Slip Additive PN 04318060AB
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
CAPACITIES
Engine, with filter..........5.1 quarts
Cooling System, Initial Fill..........8.2 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, Initial Fill..........6.6 quarts
Automatic Transmission, 41TE Initial Fill..........4.0 quarts[1]
Automatic Transmission, Total Fill
4 speed ..........8.6 quarts
Manual Transmission, T850..........5.3 pints
Manual Transmission, T350..........5.7 pints
1. With engine at operating temperature, shift through all
gears. CK level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....20 ft-lbs
Manual Transmission T350
Drain Plug.....10 ft-lbs
Manual Transmission T850
Drain Plug.....17 ft-lbs
