Assuming it hasn't been upgraded, the 327/300 hp camshaft is a mild grind used in millions of other small block Chevys. I'm sure any name brand conventional 10w30 would be up to the task, but if it were mine I'd probably look for an HDEO (diesel rated) 10w30.
How about Pennzoil GT?
A 0w60 will work just fine.
It’s a pretty dubious spec and no major manufacturer has a real rated 0w60.That is the first time I have heard of such an oil weight. Amazing that modern tech allows such an oil with that wide of a range of viscosity ratings.
Consider the source. This guy posts stuff pulled out of all sorts of locations.That is the first time I have heard of such an oil weight. Amazing that modern tech allows such an oil with that wide of a range of viscosity ratings.
Same goes for Redline Heavy Shockproof 75W250 which is NOT a 75W when cold. Great for slowing diff leaks to halt though
Redline said:
- Film thickness greater than an SAE 75W250, yet low fluid friction like 75W90
If this is a split coupe I'm envious. The '63 split coupe is my favorite Vette of all time. As for oil any modern oil manufactured in the past 25 years would probably do great in it. If the car has been restored and engine rebuilt I'd probably splurge and get something like Mobil 1 or PUP. The reason I say splurge is because in nearly 45 years of driving I've never used anything other than conventional oil I'm using 10w40 Citgo Supergard that was probably bought in the early 2000's with no problems in my '16 Versa. I ran an '88 Ford Escort to 518K miles on various brands of 10w40 from that era.What type of oil do you recommend for a 1963 Corvette 327cubic inch 300 hp engine?
