Car: 93 Trans Am, 350ci LT1, 6 speed manual
Oil: M1 SS 10w30
Under hard acceleration (WOT in either 1st or 2nd) the oil pressure in my car will drop from ~60psi down to about 45 until I let off. Not terribly low but I don't think its right either.
The strange thing is I can rev the car in neutral and the oil pressure is steady at ~60psi. I can also lift of the gas a little (80% instead of 100) and the pressure will go back up too.
The car has ~190k on it now and I'm not sure when it started (I bought it almost 4yrs ago with 118k).
Any ideas? It seems hard acceleration is the key. I was thinking either the pickup has completely fallen off the pump (thus uncovering it under high G's) or the oil is getting pushed to the back of the pan and the crank is whipping it into a foam?
Thanks!
Jason
Oil: M1 SS 10w30
Thanks!
Jason
