All good replies, interesting for sure that folks seem to go to the default "if you want to keep your warranty in tact" as a response but it seems like an almost zero risk to run whatever oil within reason that you want due to the v. low likelihood of every having the warranty need in the first place or that if there is an issue, that just showing that you changed it is more than likely enough.
Tactfulness doesn’t come into play with motor oil. If you run the oil that is specified in your owners manual and change it on schedule then the chance of a oil related failure is so small it’s almost microscopic.
