Interesting article in Infineum Insight, a fuel and lubricant additives industy journal.
GM released the spec in April 03, and has now started approving fluids. Was going to be a Dexron IIIH, but trademark considerations made this unworkable. So, it will now be Dexron III labelled as "approved againsty the H specification".
Biggest difference is the minimum performance to pass the oxidation test. Dexron III(G) was run 300 hours, the H is 450 hours.
GM Transmission Fluid Group Leader believes the new specification will not cause radical changes in additive chemicals, but it is likely that they will preclude the use of most, if not all, Group I base stocks for ATF formulation.
