Motorcraft 5W-50, 1742 miles, 2016 Shelby Mustang GT350R
GoVols
Looks like the oil is serving you well ! Are all the other changes MC as well and what filter have you been using ? Thanks for your post !👍
Erie, Colorado
Thanks! I've only used Motorcraft 5W-50 oil and the Motorcraft FL-2069-ST spin-on filter that the 2015-2017.5 GT350s use. Ford switched to a cartridge style filter in the middle of the 2017 model year due to the canister filter working loose when not properly torqued.
Santa Barbara, CA
Not sure if you would be interested but Ford Performance Parts came out with a kit to "update" the first run Voodoo engines to the later style with the cartridge filter M-6881-52CA
Erie, Colorado
I did see that and gave it some thought, but I've figured out how to easily torque the canister filter to 16-18 ft-lbs and have plenty of track days without issue. It seems that provided it is torqued to spec there's no issue with the original design. That said, plenty of dealerships couldn't figure it out and ruined a lot of Voodoos as a result. I do wonder how the cartridge filters compared to the canister. Per my UOA is seems that the canister does an excellent job.
Erie, Colorado
Ha! Thanks for all the interest! I've had the GT350R since 7/1/2016. It's the only car I haven't gotten bored of after a year or two. Here's some pictures from Circuit of the Americas in Austin. I've also had it at Utah Motorsports Campus and MSR Houston. [Linked Image] [Linked Image] [Linked Image]
GoVols
SWEET !!!🏁
Washington State
Titanium. Isn't the 5w50 Castrol Edge Pro / Supercar "infused with titanium" per their marketing lingo? Not sure this would show up on a UOA. Perhaps Castrol is Motocrafts' source.
Iron Asylum
Love it! Thanks for the pictures! thumbsup
Ocala, Florida
Beautiful ride, but with only 7K miles total and 1700 on the oil, what did you expect to see? Any oil will hold up under that OCI, unless your're living at the track doing HPDE daily...
Erie, Colorado
These aren't Accords. I don't care about the oil, I care about the engine. The Voodoo 5.2L has had several examples burn oil so badly (e.g. a quart or two in 500 miles) that Ford has replace the engine (roughly a $30K cost if done outside of warranty). There are also UOAs that show a dramatic increase in metal that coincides with oil consumption. In at least a few cases the sudden increase in metal was a precursor to total engine failure. Mine hasn't consumed excessive oil, and shows no sign of increased wear. That's what I want to find, but not necessarily what I'm certain I'd find given the issues that some 5.2Ls have had.
Erie, Colorado
Originally Posted by oldhp
Sweet lookin' car!!!!! What oil is recommended for street use?
Thanks! Ford recommends Motorcraft 5W-50 for street and track. Both Lucas and Amsoil make oil that "meets or exceeds" Ford's specifications. Given how well the Motorcraft has performed I'm not interested in experimenting.
