Motor Oil
ames, ia
Has anyone used motor oil as a "personal" lubricant?
topical, ingested, or injected - mineral oil will kill rats, and is carcinogenic. i would not use it, unless u want to die or develop a huge cancer, and then die a painful death, before becoming bankrupt from medical bills.
Don't worry. Quickly wipe the mineral oil off with a rag moistened with Xylene! A good scrubbing with lava soap and a stiff bristle brush should do, too.
While pure mineral oil has a low toxicity, some of the additives in a modern motor oil may be far more harmful. Used oil, even worse.
Originally Posted By: Zaedock
Non-detergent SAE30 would probably make a good bum lube.
Just ask your Congressman Barney Frank. aka The Banking Queen.
I only bathe in ARX.
I assume you're talking about motor oil, and I'm pretty sure its only considered a carcinogen after it's been exposed to combustion byproducts (i.e. used in an engine). I don't think it classifies as a carcinogen when it's new. Maybe in California, but you can get cancer from anything in that state.
