Just click the Reply button in the post you want to quote. Then scroll own to the Reply box at the bottom of the screen.Now, I haven't figured out how to get the QUOTE function to work yet (and don't see the option) but I figure that will come eventually as well.
I wonder if it has to do with the default color scheme of your operating system, as in, these highlight colors follow your OS color scheme, but then the OP sees different highlight colors on different forums, so maybe not?The contrast looks very reasonable to me (on this machine)
Hmmm, on my laptop, I have macOS in "dark" mode as well but my iMac uses regular, non-Dark mode. I'm not talking about themes on BITOG but the OS' 'theme'. Could be why I see a difference.I wonder if it has to do with the default color scheme of your operating system, as in, these highlight colors follow your OS color scheme, but then the OP sees different highlight colors on different forums, so maybe not?
I don't think the OP is referring to mobile devices. Actually, he refers to his computer, an iMac.I can't reproduce this on my iPhone.
Off-topic: Keep your browser up-to-date ALL the time. Your iMac doesn't get OS updates anymore, correct ? Be careful using Safari as well because I'm not sure if you can update it on it's own. It may only get updated with OS updates.I'm a little behind the times. As my cars and as my computer.
Yes sir. My iPhone is fine as well. IOS is fine.I can't reproduce this on my iPhone. All of the BITOG color schemes have good contrast of highlighted text.
Wayne, it's the default/light colored themes that could use a more 'contrasty' highlight color. The Dark theme is fine.Dark theme should now have a darker highlighted text color
It still does. I don't recall changing mine but I may have.It may have changed since but the Mac OS used to give you options for highlight colors or even make your own. It’s been a few years since I’ve been on a computer.
