LUBEGARD will have a NEW Power Steering Fluid just for HONDA in January 2020!
@ secret blending facility
REJOICE HONDA FANS!
email from Stellar Automotive Group / International Lubricants Inc.:
Thank you for contacting us!
Unfortunately, neither the 20902 or 23232 is recommended in Honda units due to the viscosity.
We will be introducing a Honda specific formula that should be available in January.
You can use our Power Steering Fluid Protectant # 20404. It is fully compatible with Honda PSF: https://www.lubegard.com/products/psf-protectant/.
Please let me know if I can do anything else.
Best regards
HAPPY HOLIDAYS
Originally Posted by JeffKeryk
O'Reilly house brand Honda fluid comes in a quart size.
I have used it in several TSXs and other Hondas.
maybe they do...
but I'm waiting for Lubegard's super special, super esoteric, super LXE® Technology ESTERS to be running through my lines!
only then I can sleep well...
some good insight with Honda Genuine Power Steering Fluid, it supposedly has very high kinematic viscosity ~ 54 cSt @ 40c, 11.3 cSt @ 100c and has different friction modifiers (zinc???)...
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1302729/2
in theory I can just add some honey-thick Lucas Transmission Fix to regular power steering fluid to bring it up to proper viscosity and add Lubegard Red/Platinum/Black for its friction modifiers, just use this viscosity calculator and mix and mix to your delight!
https://www.widman.biz/English/Calculators/Mixtures.html
Lucas Power Steering Fluid
63.0 cSt @ 40c, 8.9 cSt @ 100c
Prestone Power Steering Fluid for Asian Vehicles
53.01 cSt @ 40c - not rated at 100c
Prestone Power Sterring Fluid AS-260/261/265/266Y (gallon jug)
42.2-49.6 cSt @ 40c - not rated at 100c
Lubegard Complete Synthetic Power Steering Fluid
36.29 cSt @ 40c, 6.64 cSt @ 100c
Amsoil Multi-Vehicle Synthetic Power Steering Fluid
33.8 cSt @ 40c, 7.5 cSt @ 100c
Red Line Power Steering Fluid
31 cSt @ 40c, 7 cSt @ 100c
Lubegard Complete Power Steering Fluid
29.61 cSt @ 40c, 5.34 cSt @ 100c
Prestone Power Steering Fluid for American Vehicles AS-264Y
27 cSt @ 40c - not rated at 100c
48.0 cSt @ 100c - not rated at 40c
Lucas Power Steering Stop Leak
45.0 cSt @ 100c - not rated at 40c
with a viscosity calculator...
39.16% of Lucas Transmission Fix
60.84% of Lubegard Complete Power Steering Fluid
will yield 11.3 cSt @ 100c
28.66% of Lucas Transmission Fix
71.34% of Red Line Power Steering Fluid
19.49% of Lubegard Complete Power Steering Fluid
80.51% of Lucas Power Steering Fluid
will yield 54 cSt @ 40c, 8.4 cSt @ 100c
so yeah, Honda Genuine Power Steering Fluid is VERY SPECIAL!
Originally Posted by LotI
Just in time...for 2010. Who still uses hydraulic power assist? Dodge sedans? Nissan Frontier? Bueller?
Lubegard is focused on the aftermarket, kind of like Valvoline's MaxLife line of products... you know... for people who buy used and those that keep their vehicles way past warranty!
In the past from my searching through the LubeGard site, ILI had/has a Honda P/S fluid and a P/S fluid converter/conditioner that converts any P/S fluid into Honda-like P/S fluid and the bottles mentioned HONDA on the labels.
Is this still the case?
Is this new to come P/S fluid for electric P/S units?
Originally Posted by Char Baby
In the past from my searching through the LubeGard site, ILI had/has a Honda P/S fluid and a P/S fluid converter/conditioner that converts any P/S fluid into Honda-like P/S fluid.
first part - yes:
viscosity: 29.8-35.2 cSt @ 40c, 7.0-8.0 cSt @ 100c
since you only add 4oz of the stuff, it will barely bump up the viscosity... the Honda conversion claim is mainly due to its friction modifier additive package...
second part - no:
Honda Electric Power Steering systems do not use any hydraulic fluids!
Although some domestic & import EPS do use hydraulics and Lubegard claims it's PS protectant helps those too...
Ah yes, OK thanks!
My Altima has e-PSF but Nissan wants a bunch of $ for it. I don't have any issues with the system but, would like to top off the system or flush it entirely.
Originally Posted by edwardh1
why does honda spec a honda specific fluid (only) that is very uique?
I've heard somewhere that way back in the day Honda had major problems with their steering racks, huge recalls, and that Honda Genuine Power Steering Fluid Spec-V along with its special seals solved it...
Some good insights here from page 2:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2720114/2
Originally Posted by discountdon
if anyone has a SDS of Honda Genuine Power Steering Fluid please post it, I can't find it anywhere...
An SDS won't tell you the formulation.
Here is a properties sheet of the original Honda PS-2 Honda PN 08208-99961;
This is the original HONDA PERFORMANCE PS-2 FLUID used in the earlier Hondas and Acuras
Appearance Lt. Pale
Flash, COC, Deg F. 355
Pour Point, Deg F. -40
Viscosity, cSt
At 40 C. 53.75
At 100 C. 11.34 (The Prestone Asian Formula is similar)
Viscosity Index MIN 205
Viscosity, Brookfield cP @ -40C < 64000
Oxidation Stability, D-2272 > 200 minutes
Copper Corrosion 3A Max.
Zn Content, ppm. 1500 - Anti-Wear and Anti-Oxidant from ZDDP (not a friction modifier)
P Content, ppm. 1300 - Anti-Wear and Anti-Oxidant from ZDDP (not a friction modifier)
Mg Content, ppm 580 - See Ca
Ca Content, ppm 220 - The Mg-Ca combo serves as both a TBN adjuster and as a Friction Modifier
TBN, ASTM D-4739 5.0
The newer Honda/Acura PSF PN 08206-9002 PF has the following basic properties:
API Gravity / lbs./gal. 32.6 / 7.18
Flash Point, PMCC ºC 92
Viscosity:
cSt @ 40ºC - 31.4
cSt @ 100ºC - 6.5
Viscosity Index 167
Pour Point, max, ºF / ºC -50 / -45
Check your Honda/Acura Operator's Manual for the correct part number.
COMPLETEâ„¢ Power Steering Fluid for Honda & Acura - Product Data Sheet:
https://www.lubegard.com/wp-content/uploads/2020/01/LG_Synthetic-Power-Steering-Fluid_HondaAcura.pdf
COMPLETEâ„¢ Power Steering Fluid for Honda & Acura SDS:
https://www.lubegard.com/wp-content...ing-Fluid-for-Honda-Acura-2019-11-25.pdf
IT HAS FINALLY ARRIVED!
They will be launching the product tomorrow on the Ides of January 2020 through their Social Media Accounts!
This will be available at your local O'Reilly Auto Part stores very very soon!
Glancing at their SDS:
Product name : Lubegard® COMPLETE Synthetic Power Steering Fluid for Honda-Acura
Product code : 24242
Appearance : Transparent yellow gold liquid.
Flash point : 227 °C /440.6 °F (ASTM D92)
Relative density : 0.84 @ 60 °F (15.56°C)
Viscosity, kinematic : 51.2 cSt ( OP assumes it's @ 40ºC )
Glad it is sold by the quart
What about places where there are no O'Reilly stores?
