LUBEGARD will have a NEW Power Steering Fluid just for HONDA in January 2020!
REJOICE HONDA FANS! email from Stellar Automotive Group / International Lubricants Inc.: Thank you for contacting us! Unfortunately, neither the 20902 or 23232 is recommended in Honda units due to the viscosity. We will be introducing a Honda specific formula that should be available in January. You can use our Power Steering Fluid Protectant # 20404. It is fully compatible with Honda PSF: https://www.lubegard.com/products/psf-protectant/. Please let me know if I can do anything else. Best regards happy happy happy HAPPY HOLIDAYS
discountdon
@ secret blending facility
Originally Posted by JeffKeryk
O'Reilly house brand Honda fluid comes in a quart size. I have used it in several TSXs and other Hondas.
maybe they do... but I'm waiting for Lubegard's super special, super esoteric, super LXE® Technology ESTERS to be running through my lines! only then I can sleep well... smirk2
discountdon
some good insight with Honda Genuine Power Steering Fluid, it supposedly has very high kinematic viscosity ~ 54 cSt @ 40c, 11.3 cSt @ 100c and has different friction modifiers (zinc???)... https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1302729/2 in theory I can just add some honey-thick Lucas Transmission Fix to regular power steering fluid to bring it up to proper viscosity and add Lubegard Red/Platinum/Black for its friction modifiers, just use this viscosity calculator and mix and mix to your delight! https://www.widman.biz/English/Calculators/Mixtures.html spank
discountdon
Honda Genuine Power Steering Fluid 54 cSt @ 40c, 11.3 cSt @ 100c Lucas Power Steering Fluid 63.0 cSt @ 40c, 8.9 cSt @ 100c Prestone Power Steering Fluid for Asian Vehicles 53.01 cSt @ 40c - not rated at 100c Prestone Power Sterring Fluid AS-260/261/265/266Y (gallon jug) 42.2-49.6 cSt @ 40c - not rated at 100c Lubegard Complete Synthetic Power Steering Fluid 36.29 cSt @ 40c, 6.64 cSt @ 100c Amsoil Multi-Vehicle Synthetic Power Steering Fluid 33.8 cSt @ 40c, 7.5 cSt @ 100c Red Line Power Steering Fluid 31 cSt @ 40c, 7 cSt @ 100c Lubegard Complete Power Steering Fluid 29.61 cSt @ 40c, 5.34 cSt @ 100c Prestone Power Steering Fluid for American Vehicles AS-264Y 27 cSt @ 40c - not rated at 100c Lucas Transmission Fix 48.0 cSt @ 100c - not rated at 40c Lucas Power Steering Stop Leak 45.0 cSt @ 100c - not rated at 40c - with a viscosity calculator... 39.16% of Lucas Transmission Fix 60.84% of Lubegard Complete Power Steering Fluid will yield 11.3 cSt @ 100c 28.66% of Lucas Transmission Fix 71.34% of Red Line Power Steering Fluid will yield 11.3 cSt @ 100c 19.49% of Lubegard Complete Power Steering Fluid 80.51% of Lucas Power Steering Fluid will yield 54 cSt @ 40c, 8.4 cSt @ 100c so yeah, Honda Genuine Power Steering Fluid is VERY SPECIAL!
discountdon
Originally Posted by LotI
Just in time...for 2010. Who still uses hydraulic power assist? Dodge sedans? Nissan Frontier? Bueller?
Lubegard is focused on the aftermarket, kind of like Valvoline's MaxLife line of products... you know... for people who buy used and those that keep their vehicles way past warranty! LOL
ROCHESTER, NY
In the past from my searching through the LubeGard site, ILI had/has a Honda P/S fluid and a P/S fluid converter/conditioner that converts any P/S fluid into Honda-like P/S fluid and the bottles mentioned HONDA on the labels. Is this still the case? Is this new to come P/S fluid for electric P/S units?
discountdon
Originally Posted by Char Baby
In the past from my searching through the LubeGard site, ILI had/has a Honda P/S fluid and a P/S fluid converter/conditioner that converts any P/S fluid into Honda-like P/S fluid. Is this still the case? Is this new to come P/S fluid for electric P/S units?
first part - yes: https://www.lubegard.com/products/psf-protectant/ viscosity: 29.8-35.2 cSt @ 40c, 7.0-8.0 cSt @ 100c since you only add 4oz of the stuff, it will barely bump up the viscosity... the Honda conversion claim is mainly due to its friction modifier additive package... second part - no: Honda Electric Power Steering systems do not use any hydraulic fluids! Although some domestic & import EPS do use hydraulics and Lubegard claims it's PS protectant helps those too...
ROCHESTER, NY
Ah yes, OK thanks! My Altima has e-PSF but Nissan wants a bunch of $ for it. I don't have any issues with the system but, would like to top off the system or flush it entirely.
discountdon
Originally Posted by edwardh1
why does honda spec a honda specific fluid (only) that is very uique?
I've heard somewhere that way back in the day Honda had major problems with their steering racks, huge recalls, and that Honda Genuine Power Steering Fluid Spec-V along with its special seals solved it... Some good insights here from page 2: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2720114/2
MolaKule
Staff member
Iowegia - USA
Originally Posted by discountdon
if anyone has a SDS of Honda Genuine Power Steering Fluid please post it, I can't find it anywhere... shrug
An SDS won't tell you the formulation. Here is a properties sheet of the original Honda PS-2 Honda PN 08208-99961; This is the original HONDA PERFORMANCE PS-2 FLUID used in the earlier Hondas and Acuras Appearance Lt. Pale Flash, COC, Deg F. 355 Pour Point, Deg F. -40 Viscosity, cSt At 40 C. 53.75 At 100 C. 11.34 (The Prestone Asian Formula is similar) Viscosity Index MIN 205 Viscosity, Brookfield cP @ -40C < 64000 Oxidation Stability, D-2272 > 200 minutes Copper Corrosion 3A Max. Zn Content, ppm. 1500 - Anti-Wear and Anti-Oxidant from ZDDP (not a friction modifier) P Content, ppm. 1300 - Anti-Wear and Anti-Oxidant from ZDDP (not a friction modifier) Mg Content, ppm 580 - See Ca Ca Content, ppm 220 - The Mg-Ca combo serves as both a TBN adjuster and as a Friction Modifier TBN, ASTM D-4739 5.0 The newer Honda/Acura PSF PN 08206-9002 PF has the following basic properties: API Gravity / lbs./gal. 32.6 / 7.18 Flash Point, PMCC ºC 92 Viscosity: cSt @ 40ºC - 31.4 cSt @ 100ºC - 6.5 Viscosity Index 167 Pour Point, max, ºF / ºC -50 / -45 Check your Honda/Acura Operator's Manual for the correct part number.
discountdon
COMPLETEâ„¢ Power Steering Fluid for Honda & Acura - Product Data Sheet: https://www.lubegard.com/wp-content/uploads/2020/01/LG_Synthetic-Power-Steering-Fluid_HondaAcura.pdf COMPLETEâ„¢ Power Steering Fluid for Honda & Acura SDS: https://www.lubegard.com/wp-content...ing-Fluid-for-Honda-Acura-2019-11-25.pdf IT HAS FINALLY ARRIVED! They will be launching the product tomorrow on the Ides of January 2020 through their Social Media Accounts! This will be available at your local O'Reilly Auto Part stores very very soon!
discountdon
Glancing at their SDS: Product name : Lubegard® COMPLETE Synthetic Power Steering Fluid for Honda-Acura Product code : 24242 Appearance : Transparent yellow gold liquid. Flash point : 227 °C /440.6 °F (ASTM D92) Relative density : 0.84 @ 60 °F (15.56°C) Viscosity, kinematic : 51.2 cSt ( OP assumes it's @ 40ºC ) happy happy happy
USA
Glad it is sold by the quart happy
What about places where there are no O'Reilly stores? smirk2
